Georg
Extrapolation Control, in which models can I use it
Dear all,
I did use Extrapolation Control (JMP Pro 16.1) for some regression models as an option of the Prediction Profiler.
Recently I tried to switch it on for a Boosted Tree model, but I could not find it in the red triangle menu of the Prediction Profiler.
Is extrapolation control limited to some kind of models?
I was not easily able to find some hints on this, perhaps anyone knows?
Prediction Profiler Options (jmp.com)
Georg
Re: Extrapolation Control, in which models can I use it
Hi Georg,
You can find the extrapolation control in the following platforms in JMP Pro 16:
Standard least squares
Neural
Generalized Regression
Naïve Bayes
Support Vector Machines (SVM)
Partial Least Squares (PLS)
Structural Equation Models (SEM)
Profiler from the Graph menu (which profiles any equation)
I hope this helps.
Laura
Hi Georg,
Neural
Naïve Bayes
I hope this helps.
Laura
