Extracting numbers from a set of numbers in a column
Jul 29, 2015 10:36 AM(5384 views)
Let say you have the following data table with 6 digits numbers in one column (Number 1) and you are interested in extracting only 4 numbers from those 6 numbers into a new column (Derived Numbers). How do you go about doing that? Thanks in advance.
Thanks, I figured it out Here is screenshot. I used the Left from the Character function group and selected the number of numbers that I want to extract from the original table.
The screenshot is actually a screenshot from one of data tables, which I was working with yesterday. For this specific example your formula would rather be:
Left(Number 1, 4)
Jenkins Macedo
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '13607' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '13607') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '13607') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
