eugur
Extracting characters within certian pattern including square brackets
I have want to extract information from a text in a table row that includes square brackets.
Example Rows in text column:
Plate[QWE147] Reg[ABC123]
Plate[ASD258] Reg[DEF456]
Information I want to extract:
ABC123
DEF456
What is the best way to do this? I wanted to do it with regex but square brackets makes it complicated.
Re: Extracting characters within certian pattern including square brackets
You have to do some escaping
str1 = "Plate[QWE147] Reg[ABC123]";
str2 = "Plate[ASD258] Reg[DEF456]";
Show(Regex(str1, "Reg\!\[(.+)]$", "\1"));
Show(Regex(str2, "Reg\!\[(.+)]$", "\1"));
Also using Word(-1,...) might be enough if your strings are simple enough
Show(Word(-1, str1, "[]")); // Word(-1, str1, "[]") = "ABC123";
Show(Word(-1, str2, "[]")); // Word(-1, str2, "[]") = "DEF456";
eugur
Thank you. This works perfect. Could you please explain why "$" is in the code?
Most likely unnecessary, but it just tries to make sure it matches at the end
pmroz
You can also use the word function:
show(word(4, str1, "[]"));
show(word(4, str2, "[]"));
