cchueng
Extract words from String Column
How do I create an Output1 column to extract all the words starting with "_D" from a column called String1?
String1                                      Output1
PRD_D30405_v1                     D30405
PRD_MH1_D4375                   D4375
FET-D3245_v2_D43453          D43453
BDT_33tr-ge_DT3746_v2       DT3746
Re: Extract words from String Column
Here is the formula that I used to get your result
Word( 1, Substr( :String1, Contains( :String1, "_D" ) + 1 ), "_" )
You can also use Regex. This should work with your examples
Regex(:String1, "_(D[A-Z0-9]+)", "\1");
