swiergi11
Extract a value from text
Is it possible to extract the 550 value from the text below using JMP formula that i could then imbedded into script. The over all shape and number of characters will change but the expression of std Pli = will stay the same.
Any help would be greatly appreciated.
Thanks,
Tomasz
PP, PPr (don’t forget to measure standard wafer SMM PPr WAL S0782-3, "Redarect PPr new" recipe (On WE9LDIP ONLY)) and UVX all (redirect), and run on click vale for mismatch info, Final PP
std Pli = 550 average value1 = … (Run/Std = >5.00) 100 / 120 = 0.8333
DOD tap and bottom on monitor only.
Re: Extract a value from text
You can use JMP's string operations for this. Read up on Contains(), Munger(), Substr(), Word(), Words(), Right(), Left(), etc. Here I've used munger and contains to isolate the number. The num() function changes the string found, "550" into the number 550.
Cheers,
Brady
txt =
"\[PP, PPr (don’t forget to measure standard wafer SMM PPr WAL S0782-3, "Redarect PPr new" recipe (On WE9LDIP ONLY)) and UVX all (redirect), and run on click vale for mismatch info, Final PP
DOD tap and bottom on monitor only.]\";
beg = Contains( txt, "std Pli = " ) + 10;
end = Contains( txt, " ", beg );
val = Num( Munger( txt, beg, end - beg ) );
Many ways to do this in JMP. Here is one:
str = "\[PP, PPr (don’t forget to measure standard wafer SMM PPr WAL S0782-3, "Redarect PPr new" recipe (On WE9LDIP ONLY)) and UVX all (redirect), and run on click vale for mismatch info, Final PP
DOD tap and bottom on monitor only]\";
searchString = "std Pli = ";
//substr
firstSplit = Substr(str, Contains(str, searchString) + Length(searchString));
substr_result = Substr(firstSplit, 1, Contains(firstSplit, " ") - 1);
Show(substr_result);
Also if know how use regex you could use that:
regex_result = Regex(str, "(std Pli = )(\d+)", "\2");
Show(regex_result);
swiergi11
thanks a lot, all suggestions works well.
