cedricb
Extract USL & LSL for all tests of my data table
Hi all,
I just start working on Jump 10.
I am trying to extract from a data table all USL & LSL for all the tests and then I would like to create a new table bluit as:  Test number | Test name | LSL | USL.
Any ideas to help me please ? Or any tutorials ?
Thanks in advance.
Rgds,
CedricB
senatorx
Re: Extract USL & LSL for all tests of my data table
I would look into using the Summary command from the Tables Menu.  Or if using JSL script, you would use the Summarize(...) Function.
Jeff_Perkinson
You can use the <<Get Property("Spec Limits") message on a column to get the spec limits and then put them into a data table.
Try something like this:
dt = Current Data Table();
specs = New Table( "SpecLimits.jmp",
  New Column( "ColName", Character, Nominal, width( 30 ) ),
  New Column( "LSL", Numeric, Nominal ),
  New Column( "USL", Numeric, Nominal ),
  New Column( "Target", Numeric, Nominal )
nc = N Col( dt );
For( i = 1, i <= nc, i++,
  If( Column( dt, i ) << get data type() == "Numeric",
  If( !Is Empty( x = Column( dt, i ) << get property( "Spec Limits" ) ),
  specs << add rows( 1, N Row( specs ) );
  Try( Column( specs, "lsl" )[N Row( specs )] = x["lsl"] );
  Try( Column( specs, "usl" )[N Rows( specs )] = x["usl"] );
  Try( Column( specs, "target" )[N Rows( specs )] = x["target"] );
  Column( specs, "colname" )[N Rows( specs )] = Column( dt, i ) << get name;
-Jeff
-Jeff
