William_S
Exporting Select Columns to CSV Filtered by Formula Column
Hey everyone,
I'm new to JMP scripts and I'm hoping this may help others too.  From the sample data screenshot below (stored as a .JMP file), I'd like to select Material and Month and round Stock to a whole number.  I'd then like to filter only records where the rounded Stock calculation is greater than zero.  Finally I'd like the results to be saved as a CSV file.
Here is my initial attempt at a JSL version.  I'm pretty sure I'm not using the dt expressions correctly (likely among several other things as well)  Any help would be tremendously appreciated.
dt = Open( "$SAMPLE_DATA\My JMP Table.jmp" );
columns(
		:Material,
		:Month,
		New Column("Stock Integer", Numeric, "Continuous", Formula(Round( :Stock,0))
dt << Select Where Formula(Round( :Stock,0)) >=0
dt << save( "$Desktop\test.csv" );
Here is an SQL-like equivalent of what I'm trying to do
SELECT
	[My JMP Table].Material,
	[My JMP Table].Month,
	Round([My JMP Table].Stock,0) AS Stock_Integer
INTO
        test.csv
FROM
        [My JMP Table]
WHERE
        Round([My JMP Table].[Stock],0)>0
Thanks so much!
Re: Exporting Select Columns to CSV Filtered by Formula Column
I put this together quickly but it should work or be close.
dt1 = Open( "$SAMPLE_DATA\My JMP Table.jmp" );
For Each Row( :Stock = Round( :Stock, 0 ) );
dt1 << Select Where( :Stock >= 0 );
dt2 = dt1 << Subset( Selected Rows( 1 ), Columns( :Material, :Month, :Stock );
dt2 << Save( "$Desktop\test.csv" );
You were on the right path!
William_S
Wonderful, that worked perfectly. Thank you so much!
