hockswender
Exponential Decay - Fit Curve
I want the Scale term (a) to =1.0; I'm using FitExponential 2P; can I specify the scale factor somewhere in Fit Curve or do I need to use a different platform?
Re: Exponential Decay - Fit Curve
You need to define your model as a formula in a new column and then choose Nonlinear platform.
hockswender
Thanks, it worked ok.
