Expand Contours
I understand that the contouring is done based on triangulation to data points, but is there a method for expanding them further to fit a custom SHP file I've imported into JMP? I've already set the alpha and the lowest value so the contour should cover the, 'most', area. Any other methods?
Thanks!
M. Dereviankin
0 REPLIES 0
