Ole
Ole
Executing file from Office sharepoint directly
I am in progress of transferring my scripts to the companies new office 365 account. I would like to be able to access and execute the jsl's (and csv's, html,s) directly from sharepoint with a link like
include("https://company.sharepoint.com/sites/Site_Name/Shared%20Documents/General/Data_Center/01_scripts/01_...");
so that all jmp users can run the same script pressing a button from a journal I created.
I get an error message failed because of: Internet error 403 ...
If I try to open the link directly from JMP I get the following error message:
Is there a way to run the jsl from this link (and similarly open, save and close excel and html's)?
Thanks
Ole
ih
Super User (Alumni) ih
Re: Executing file from Office sharepoint directly
Hi @Ole,
One option is to open the page in a JMP web browser window first.  Have a look at these threads:
Open microsoft office 365 cloud-based excel from JMP/JSL?
How to extract data from an Excel file on Sharepoint?
ih
Hi @Ole,
Ole
Ole
Sorry for the late reply. I changed company and as I now came into the same situation again I had to retry the fix you proposed. It took me some time but eventually got it to work. The one thing that threw me off was that I didn't run the command below first. It has only to be run one time. After that the connection between JMP and Office is established:
Web( "https://company.sharepoint.com/:x:/r/sites/Folder/filename.xlsx", JMP window );
The command
Web( "https://teams.microsoft.com", JMP window );
that was used in the embedded links doesn't work with the newest version of Office.
