RyMcQeN
Exclude rows from linked Summary table
I have a linked summary table that I am trying to exclude rows based on some criteria of the cell contents for specific columns.  The objective is for the rows in the linked table to also become excluded.  I know it is possible to do this outside of JMP scripting but for some reason I get an error in JSL.
dtSummary = dt << Summary( Group(:age), Link to original data table(1));
r = dtSummary << Get Rows Where(:age == 14);
r << Exclude;
My actual code has more complicated row selection criteria but the above example has the same idea.
The error returned is:
ERROR: Send Expects Scriptable Object in access or evaluation of 'Send' , r << Exclude;
I appreciate any help in advance.
Thx,
Ry
cwillden
Re: Exclude rows from linked Summary table
Change "Get Rows Where" to "Select Where"
r = dtSummary << Select Where(:age == 14);
r << Exclude;
This worked on my end.  Better yet, you can do it this way:
dtSummary << Select Where(:age == 14) << Exclude;
Get Rows Where() returns a list or the row numbers that meet the criteria.  Sending an Exclude message to a list of numbers doesn't do anything, so that's why it wasn't working.
-- Cameron Willden
cwillden
r << Exclude;
-- Cameron Willden
RyMcQeN
Thank you for the quick response. I had tried Select Where earlier but had the wrong syntax. Appreciate the help!
-Ry
