FN
FN
Evaluating an algebraic expression introduced as strings
I have a character column that has the duration of different processes in the following format:
3h 40min 15s
3h 47min 19s
5min 6s
29min
I changed this to another character column with find and replace:
3*3600 + 40*60 + 15
3*3600 + 47*60 + 19
5*60 + 6
29 * 60
How can I add a formula that evaluates each expression when the expression is a string?
This works:
Eval( Expr( 3*3600 + 40*60 + 15 ) )
But the formula doesn't as the expression is in characters:
Eval( Expr( "3*3600 + 40*60 + 15 "))
Re: Evaluating an algebraic expression introduced as strings
Eval(Parse()) is what you would want to use in case like this
Eval(Parse("3*3600 + 40*60 + 15 ")); // 13215
