R2OKeefe
Error when Saving Project File
I keep getting an error when trying to save a project file that says:
Project has unsaved documents. All files in a project must be saved or closed before the project can be saved. at row 1629.
One of my tables has 1629 rows, but it is already saved in the script a few lines above. I even tried manually saving each file again, then tried running the JSL to save the project, and I get the same error again. The only files currently open in the project are the two data tables (dt and dt2), and the script I am running this from. Both "filepath" and "PrjTitle" are variables that get assigned based on user input from modal windows earlier in the script.
dt << Save As( "$PROJECT/"||char(dt<<GetName)||".jmp" );
dt2 << Save As( "$PROJECT/"||char(dt2<<GetName)||".jmp" );
Wait(0.5);
Project << Save as( filepath||PrjTitle||".jmpprj" );
I also tried Save instead of Save As, but got the same result.
Wait(0.5);
Project << Save( filepath||PrjTitle||".jmpprj" );
My only theory right now is that it has something to do with me trying to save the files to the project itself, but I don't see anything on the forums, scripting guide, scripting index, etc that says anything about that being something that cannot be done. The only things I could find were statements that you cannot save a project using JSL if there are unsaved files in the project, like this one here near the bottom of the page:
Note: If you're saving a project with unsaved documents in JSL, the project doesn't close and you get a log message that the project has unsaved documents. All files in a project must be saved or closed before the project can be saved. However, if you interactively save a project with unsaved documents, you are prompted to save the documents.
Source: https://www.jmp.com/support/help/en/17.1/index.shtml#page/jmp/create-a-project-with-a-bookmarks-pane...
Currently using JMP 16.2.0, in Windows 10.
12 REPLIES 12
Clanlope
Re: Error when Saving Project File
Hi, is there any way to fix this issue on JMP16 if updated ver is not available? thanks
Unfortunately, the final maintenance release of JMP 16 came out a number of years ago; you'd need to upgrade to JMP 17, 18, or 19 to get the fix.
Clanlope
Got it, thanks for your replying
