ehchandlerjr
Level V
Error column property
Hello - I have a data set that comes from an external measurement and the software that comes with the instrument automatically calculates the property and error bars that I'm looking for. Is there a way to include the error as a column property without doing a custom column property? I know there's a saved model error property, but fitting a custom model would introduce it's own issues as the model applies only to part of each dataset, and it changes with each data set, so unless fit curve has a way to dynamically test fits to different portions of the curve easily, I'd rather just enter it. It's really not necessary, but I'm trying to make JMP to ultimate repository of the data for this project and since I have error bars, I'd like to include it if possible.
Thanks!
Edward Hamer Chandler, Jr.
0 REPLIES 0
