its_JIM
Error Starting JMP
I get the error below when I try to display pulled data from SQLPathfinder to create a chart.
How do I resolve this?
Re: Error Starting JMP
To me that doesn't really seem to be a JMP problem but rather with your SQLPathfinder application. Have you tried what the error message suggest (check configure form)? Or have you contacted SQLPathfinder developers?
its_JIM
Now that you mentioned it, I will reach out to the SQL Pathfinder folks to see if they have a solution or something - I am unable to locate the "Configure Form", so it's hard to try troubleshooting it.
its_JIM
Issue fixed, I notice my JMP path in SQL Pathfinder was pointing to JMP14 instead of JMP17. I corrected that and worked.
XzavierRhett
My problem has also been solved. Thank you so much for your suggestions.
