Martin
Level V
Enable Modal Radio Box Items based on predefined list
I am trying to Enable/Disable certain radio box buttons in a single radio box based on a list I have entering the Modal dialog with.
For instance, say my list is {2, 5} and my radio box has 5 buttons in it. When the Modal window opens, I only want buttons 2 and 5 (from the list, which is based on previous user input) to be enabled and buttons 1, 3, and 4 to be disabled.
I've tried to add a For loop and an If loop with a Contains formula into the setting up of the radio box, but they seems to only get called when a different button is clicked in the radio box, not when it is originally set up.
Any help would be greatly appreciated.
Re: Enable Modal Radio Box Items based on predefined list
Would example like this help?
//radiobox variables
enableList = {2,5};
rbItems = {"one", "two", "three", "four", "five"};
rb = Radio Box(rbItems);
//start as all disabled
For(i = 1, i <= N Items(rb << get items), i++,
	rb << enable item(i,0);
//enable based on enableList
For(i = 1, i <= N Items(enableList), i++,
	rb << enable item(enableList[i],1);
//change first selection to first in enableList (otherwise will be first in rbItems)
rb << Set(enableList[1], 1);
//create modal
ok_pressed = 0;
ex = New Window("Dialog() example",
	<<Modal,
	V List Box(
		rb,
		H List Box(
			Button Box("OK", ok_pressed = 1; rbSelection = rb << get),
			Button Box("Cancel", ok_pressed = 0)
If(ok_pressed == 1,
	show(rbSelection);
	show(rbItems[rbSelection]);
enableList = {2,5};
//create modal
ok_pressed = 0;
	<<Modal,
	V List Box(
		rb,
		H List Box(
If(ok_pressed == 1,
	show(rbSelection);
Martin
Level V
Thanks Jarmo!
This works exactly like I had hoped. I was not thinking of "pre setting up" the radio box, before showing it.
Martin
