danielrbiber
Else Statement not returning in column formula
I'm creating a new column with some regex statements.  I have the tough regex bit figured out but the else statement returns <no data>?  Any ideas as to why this is?  I have several other if containing column formula of the same syntax that return the else statements.
The formula should return the integer directly before " ct" or "ct" or should return "bulk".
For example:
:Packaging          :Packaging_Ct
abso 400ct           400
ebso 100 ct          100
fiber                      bulk
Data Table("MetaDataGelSplit") << New Column(
	"Packaging_Ct",
	Character,
	Nominal,
	formula(
		If(
			Num( Regex( :Packaging, "\d+(?=\s+ct)" ) ) > 0, Regex( :Packaging, "\d+(?=\s+ct)" ),
			Num( Regex( :Packaging, "\d+(?=ct)" ) ) > 0, Regex( :Packaging, "\d+(?=ct)" ),
			"bulk"
Thanks in advance for the help.
Re: Else Statment not returning in column formula
If a numeric value is not found in the Regex it does not return a zero, it returns a missing value, by changing the comparisons to using IsMissing() the logic works correctly
current data table() << New Column(
	"Packaging_Ct",
	Character,
	Nominal,
	formula(
		If(
			isMissing(Num( Regex( :Packaging, "\d+(?=\s+ct)" ) )) ==0, Regex( :Packaging, "\d+(?=\s+ct)" ),
			isMissing(Num( Regex( :Packaging, "\d+(?=ct)" ) )) == 0, Regex( :Packaging, "\d+(?=ct)" ),
			"bulk";
	"Packaging_Ct",
	Character,
	Nominal,
	formula(
		If(
			"bulk";
Re: Else Statmente not returning in column formula
In addition to @txnelson's advice, I try to build up the formula by starting with the basic Regex() function. That is, before applying Num(), make sure that you are getting what you need from Regex() first. Don't add unnecessary layers to the formula until you are satisfied that the lowest level is working for you.
Also, Regex() is relatively 'expensive,' so I would save the result from the first call in a variable and re-use it instead of call Regex() again with the same expression. it might make a big difference in large data tables.
vince_faller
Seems like you could cut out one of the regex entirely as well.
n = Regex( :Packaging, "(\d+)(?=\s*ct)", "\1");
if(ismissing(num(n)),
	"bulk",
	num(n)
Vince Faller - Predictum
