pticguy
Editing chart with 'Dispatch'
JMP 9.0.3
Windows 7 Enterprise SP1
I am trying to edit some 'control chart' display parameters using 'Dispatch'. It seems like the only way I can get the command to work is if I use the string for the chart title directly. I need to be able to pass that name into the Dispatch command somehow. Here's my 'not working' script:
xbarname = eval("XBar of "||Testname);
Control Chart(
      Sample Label( :Sample ),
     Chart Col( :Testcolumn,
           XBar(
                Box Plots( 1 ),
                Connect Points( 0 ),
             Dispatch(
                  {xbarname},
                                     "2",
                  ScaleBox,
                  {Min(1), Max( 1.5 ), Inc( 0.05 ),
                  Minor Ticks( 1 )}
pmroz
Re: Editing chart with 'Dispatch'
I tried but couldn't find the magic combination of eval, parse, expr that will make it work directly.  When faced with situations like this I tend to use a brute force approach.  Basically you build a string dynamically and execute it with eval(parse()).  Using evalinsert allows clean insertion of parameters, in this case xbarname.  Also, using the constructs \[ and ]\ allow for embedding of double quotes without the need to escape them, which also gives the code a cleaner look.
testname = "Temperature";
xbarname = "XBar of " || Testname;
cc_expr = evalinsert("\[
Control Chart(
    Chart Col( :Testcolumn, XBar( Box Plots( 1 ), Connect Points( 0 ), ), ),
        Dispatch(
            {"^xbarname^"},
            "2",
            ScaleBox,
            {Min( 1 ), Max( 1.5 ), Inc( 0.05 ), Minor Ticks( 1 )}
eval(parse(cc_expr));
pmroz
Control Chart(
        Dispatch(
            {"^xbarname^"},
            "2",
            ScaleBox,
