Mytom
Easy DoE
Hi!
Is it possible to obtain a response surface graph if I use an Easy DoE option? Under the "Prediction" tab I can only see the prediction profiler.
Phil_Kay
Re: Easy DoE
Hi @Mytom ,
Good question. I assume that you mean a surface profiler plot.
I think this is a case where currently you would need to export the data, which you can do from the Analyze tab, and run the model in Fit Model - there should be a script in the exported table for that.
You might want to make this request on the JMP Wish List.
I hope this helps,
Phil
