BookmarkSubscribeRSS Feed
ravi_jmp
Community Trekker
Nov 3, 2011
Dynamic column formula
I am generating new columns by adding some columns. The columns to add, I get the names from a file and build the names as a array list. The column names and number of columns could change. When the number of columns change, I am having to edit the formula to reflect the change. Using the column names array list, is there a way of dynamically adding them in the formula, without having to specify every column I want to add,
dt=current data table();
Cols=Associative Array();
Cols["A1"]={ColA, ColB, ColC};
Cols["A2"]={ColE, ColF, ColG};
Cols["abc"]={"Total1", Total2};
newcolExpr = Expr (
            dt << New Column(Counts["abc"][1], Numeric, Continuous, Formula( If(Expr(Cols["A1"][1]) + Expr(Cols["A1"][2]) + Expr(Cols["A1"][3]) > 0,1,0)));
            dt << New Column(Counts["abc"][2], Numeric, Continuous, Formula( If(Expr(Cols["A2"][1]) + Expr(Cols["A2"][2]) + Expr(Cols["A2"][3]) > 0,1,0)));
        Eval(Eval Expr( newColExpr));
I would appreciate any suggestions for my problem.
ms
Jun 23, 2011
Re: Dynamic column formula
One way to dynamically build expressions from strings. In comparision to expressions, I think strings are more easy to manipulate.
Here an example. It "must" be a simpler way but it works.
Clear Globals();
//Make example table
dt = New Table( "test",
  Add Rows( 3 ),
  New Column( "A", Numeric, Continuous, Format( "Best", 1 ), Set Values( [0, 1, 1] ) ),
  New Column( "B", Numeric, Continuous, Format( "Best", 12 ), Set Values( [0, 2, 2] ) ),
  New Column( "C", Numeric, Continuous, Format( "Best", 12 ), Set Values( [0, 3, 3] ) ),
  New Column( "D", Numeric, Continuous, Format( "Best", 12 ), Set Values( [4, 0, 4] ) ),
  New Column( "E", Numeric, Continuous, Format( "Best", 12 ), Set Values( [5, 0, 5] ) ),
  New Column( "F", Numeric, Continuous, Format( "Best", 12 ), Set Values( [6, 0, 6] ) )
//define the criteria array
Cols = Associative Array();
Cols["A1"] = {A, B, C};
Cols["A2"] = {D, E, F};
Cols["abc"] = {"Total1", "Total2"};
//Make substrings iteratively
s1 = "Expr(Cols[\!"A1\!"][1])";
For( i = 2, i <= N Items( Cols["A1"] ), i++,
  s1 = s1 || " + " || Substitute( "Expr(Cols[\!"A1\!"][_i_])", Expr( _i_ ), Char( Eval( i ) ) )
s2 = "Expr(Cols[\!"A2\!"][1])";
For( i = 2, i <= N Items( Cols["A2"] ), i++,
  s2 = s2 || " + " || Substitute( "Expr(Cols[\!"A2\!"][_i_])", Expr( _i_ ), Char( Eval( i ) ) )
// Strings representing expressions, substitute _s_ for substrings
newcol_s1 = "dt << New Column( Cols[\!"abc\!"][1], Numeric, Continuous, Formula( If(  _s_  > 0, 1, 0 ) ) )";
Substitute Into( newcol_s1, Expr( _s_ ), s1 );
newcol_s2 = "dt << New Column( Cols[\!"abc\!"][2], Numeric, Continuous, Formula( If(  _s_  > 0, 1, 0 ) ) )";
Substitute Into( newcol_s2, Expr( _s_ ), s2 );
//Parse complete strings
e1 = Parse( newcol_s1 );
e2 = Parse( newcol_s2 );
//Make new columns by evaluating the substring expr and then the complete expressions.
Eval( Eval Expr( e1 ) );
Eval( Eval Expr( e2 ) );
ravi_jmp
Community Trekker
Nov 3, 2011
Hi MS,
Thanks for the detailed example. Lots of manipulation involved with strings, but I can't see any other simpler way to do this.
David_Burnham
Jul 13, 2011
There are a couple of notations that you can use which can often help dynamic jsl more readable:
If you need to include quotes in strings, instead of using the \!" notation which becomes tedious you start the string with "\[   ... then all subsequent escaped characters dont need the \! notation - you finish the string with ]"
For example:
str = "\[ "Hello World" ]\";
show(str);
show(Parse(str))
Secondly, if you are constructing a jsl command dynamically using variables, you can use the EvalInsert function that allows you to insert a variable using the notation ^my_variable^.  This avoids the need for using SubstituteInto.
Combining the two methods you can wrap dynamic code using the following pattern:
Eval(Parse(EvalInsert("\[
     jsl-statements here using ^var^ notation for subtitution
For example:
Clear Globals();
  Add Rows( 3 ),
Cols["A1"] = {"A", "B", "C"};
          s1 = Cols["A1"][1];
              s1 = s1 || "+" || Cols["A1"][^i^]
   newcol_s1 = dt << New Column( Cols["abc"][1],
   numeric, continuous,
   formula( If (^s1^ > 0, 1, 0 ) )
-Dave
