RonB
Dynamic Time Warping DTW
I'm a bit confused about how to use DTW.
My data ~300K rows with:
1st column - test number 1 to 4
2nd column - time. For each test, time starts at 0 and goes up in increments of 0.2 ms.
Eight columns of measurements.
Rows are ordered by test and time.
What is the proper way to align with DTW?
Thanks
Re: Dynamic Time Warping DTW
The Functional Data Explorer Platform allows for multiple data table formats to be used.  From your description, your data appears to be in a Stacked format.
Specifying your measurement columns as the Y variables, and your Test column as the ID variable, you should be able to get your response.
I suggest you read the Functional Data Explorer section in the  "Predictive and Specialized Modeling" book.
     Help==>Books==>Predictive and Specialized Modeling
RonB
Thanks, that helped.
Alas, DTW on my complete data set (300K rows) gives an error "to process DTW". No such error when I DTW a smaller subset. Any idea what might cause that error?
I assume there is a data issue. My suggestion is to contact JMP support directly
[email protected]
