Created:
Sep 26, 2022 06:16 AM
| Last Modified: Sep 26, 2022 3:26 AM(3563 views)
| Posted in reply to message from Flavy 09-26-2022
I think all you need to do is to drag all 3 of your Y variables at the same time to the Y axis drop area, rather than having them as 3 separate columns.
Created:
I strongly suggest that you read the Graph Builder chapter from the Essential Graphing document in the JMP Documentation Library, available under the Help pull down menu.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '549028' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '549028') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '549028') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
