moti617
Duplicate a column
I'm relatively new to scirpting..
I'm interested in simply duplicate a column within the existing table. I would the duplicated column to be last and have a different name.
After that, I would like to annonymize the original column.
Thanks
uday_guntupalli
Level VIII
Re: Duplicate a column
@moti617,
dt = Open( "$SAMPLE_DATA/Big Class.jmp" );;
dt << New Column("weight-dup",numeric,continuous,formula(:weight));
dt:weight-dup << delete formula ; // optional
Best
Uday
moti617
Thank you,
Happen to know the sript for annonyizing a column?
uday_guntupalli
Level VIII
@moti617,
       Try the following.
dt << anonymize( columns( :name, :age ), output table name( "anonymized" ) );
      Also, the following are really useful resources that you have at your disposal, that you should try and start exploring:
1. Scripting Index
2. Sample Data
3. Books
Best
Uday
moti617
Thank you!
Appreciate the help.
