Neo
Neo
Dotted line to indicate start and end of a JSL code section with brackets
I am leaning JSL and found this (here).  The start and the end of a code section with brackets is shown indicated by a dotted vertical line, which I find very useful.
I am on JMP13. How do I implement this in the settings?
demoKernel
Thanks.
When it's too good to be true, it's neither
Re: Dotted line to indicate start and end of a JSL code section with brackets
Cold Folding is a preference in the Script Editor group. Select File > Preferences and then select Script Editor in the list on the left side.
Neo
Neo
I am afraid, setting "code folding" is not working for me. After checking "code folding" on, I restarted JMP, still do not see what the "vertical dotted line"..... What am I doing wrong (I am on JMP 13)?
Neo
Neo
working now. Thanks.
