jrphage
Does jmp allow the contents of a cell to be a hyperlink
Is it possible in jmp to make the contents of a cell a hyperlink such that when a user clicks on a cell it can open the hyperlink?
Jeff_Perkinson
Re: Does jmp allow the contents of a cell to be a hyperlink
Sure. JMP 14 added the Event Handler Column Property.
If your column is the URL you want to open on a Click then just add the Event Handler property and the default Click script will open that URL in your web browser.
Alternatively, if you want to make something else clickable, you can build the URL out of information in your table and use that as the argument to the Web() function in the Click script.
Event handlers can do a lot more than just hyperlinks. I'll try to expand on them in a blog post soon.
-Jeff
stan_koprowski
Hi @jrphage,
If you are using JMP 14 you can set it with a column property entitled event handler.
Books-->Scripting Guide and search for event handler.
"...You can define a text column as a column of hyperlinks using the Event Handler column property. For example, you can create a column of geographical data as links to a Google map, or you might want to include links to a Wikipedia web pages..."
16 REPLIES 16
Select the data column. Select Cols menu > Column Info. Change the Data Type attribute to Expression.
jrphage
Thanks so much!  So if I change the column info as you suggested and then add something like "http://www.jmp.com" to the contents of the cell, it should then treat that cell as a hyperlink?  I have tried that and it doesn't seem to be working.
I am sorry. That change is necessary but not sufficient. With the new Expression data type, you also have to add associated Expression Role column property to indicate how the data in this column is to be used. The four roles that are available are Picture, Matrix, Expression, and Picture Expression. There is also the Event Handler column property, which is what I think you need to specify the action associated with a hyperlink. This is what the Using JMP guide has to say about the Event Handler property:
Use the Event Handler column property to define hyperlinks in a text column. The hyperlinks can be used to open web pages and other documents. Add the Event Handler to a column of URLs to open the URLs in a browser. (Hyperlinks to web pages in the text column must include “www”.) You can also modify the placeholder scripts on the column property to open different kinds of resources. For example, in a data table of geographical data, you might edit the Click script to display a Google map when the user clicks the hyperlink in the data table. The SAS Offices.jmp sample data table provides examples.
I admit that I saw this feature introduced a long time ago but I have not used it myself since that time. Perhaps another user will help at this point with an example or further explanation.
Jeff_Perkinson
-Jeff
jrphage
Thanks so much everybody.  Is this a feature only in JMP 14, or can I do it in JMP 13?  I am currently using JMP 13.
Jeff_Perkinson
It is new in JMP 14. As @Mark_Bailey alludes, it can be done with Expression columns but it's quite a hack and not as useful as what's in JMP 14.
-Jeff
stan_koprowski
Hi @jrphage,
JensRiege
Is there a example that can demonstrate this in a simpler way? The example in the guide appears very complicated. Can someone provide a simple JSL example of just a column with two rows, where there is a hyperlink in each of the two rows?
