csoon1
Does JSL provide a "busy" indicator similar to a spinning wheel or bar?
I am processing hundreds of thousands of rows and I wanted something "visual" to tell the user that the script is doing something. I appreciate any hints or tricks to achieve this.
14 REPLIES 14
msharp
Re: Does JSL provide a "busy" indicator similar to a spinning wheel or bar?
I like your use of functions to accomplish the same thing, makes it cleaner.
A few things I've learned from when I scripted mine above, if the user decides to close the window it will crash your script.  I'd suggest looking at my code I attached above.  Uses try/catch and allows the user to hit cancel as well.  Also, feel the Show Menu(0), and Show Toolbar(0) makes a loading bar a little cleaner for the window.
I like the cancel button and the x-axis percentage.  The Show Menu(0) and Show Toolbar(0) is pretty cool too.
pmroz
Craige,
Somehow the website munged a portion of your code.  See the middle line below:
spacerbox(size(20,20)),
  progress:busy = Busy Light( <
  Border Box( Left( 20 ), Right( 20 ), top( 20 ), bottom( 20 ),
stan_koprowski
Yes. It does look like the translator removed some of the key elements.
I'll see if I can get the translation to stop being so greedy.
In the meantime, if you uncheck the the Translate Page to: option it will show the missing characters.
Stan
Thanks, I attached a copy of the script.  I suspect the less-than less-than in the JSL makes some browsers unhappy.  I've noticed the three browsers I often use render the community pages differently.  Progress Bar
