m4mazzotti
Does JMP have a SumIf equivalent in Column Formula Editor?
I will explain what I am trying to achieve with an example
ID Value Sum
1 5 13
1 6 13
2 9 9
3 1 1
1 2 13
I have a column with a bunch of IDs, they can repeat. Then a have a second column with different values for those IDs.
On the 3rd column, I am trying to have a formula to sum all the Values from all the rows that have the same ID as the current row.
For Row 1 we have, ID = 1, so 5+6+2= 13
Any ideas on how to do that?
Re: SumIf equivalent in Column Formula
Using the ColSum() function with a second argument to specify a By variable should work. The script below recreates your table, using a formula for the third column:
New Table( "Data",
     Add Rows( 5 ),
     New Column( "ID",
     Numeric,
          "Continuous",
     Set Values( [1, 1, 2, 3, 1] )
     New Column( "Value",
     Numeric,
          "Continuous",
     Set Values( [5, 6, 9, 1, 2] )
     New Column( "SumIf",
     Numeric,
          "Continuous",
         Formula( Col Sum( :Value, :ID ) )
Hope that helps,
Michael
Michael Crotty
Principal Statistical Writer
Manager, Statistical Documentation
JMP Development
New Table( "Data",
     Add Rows( 5 ),
     New Column( "ID",
     Numeric,
          "Continuous",
     Numeric,
          "Continuous",
     Numeric,
          "Continuous",
Hope that helps,
Michael
Michael Crotty
JMP Development
