No, residuals are calculated as (observed - expected) / sqrt(expected). If the value is greater than 2 or less than -2, then that cell is a significant contributor to the variation. Basically, it's the post-hoc test for the Chi-square test. I can do it by hand in Excel since it's an easy calculation and JMP does display the observed and expected values in the table, but it's time consuming and tedious. I was hoping for a quick, automatic way to generate them.
