gandi2223
Disable exit dialog
Is there a way to disable the dialog that's shown upon exiting JMP ("Closing this window will cause JMP to exit. What would you like to do?"). No other program requires a confirmation of this type, I don't see why JMP should. Clicking the X in the top right of the window (on a Windows machine) should be enough to quit JMP, no further questions required.
11 REPLIES 11
Oestfeldt
Re: Disable exit dialog
Absoluty wonderful.
Does a similar command line option exist to disable the Alert dialog, when closing Data Tables?
hogi
Level XIII
when you try to close hundreds of tables?
you could select them in the home menu and press "del", then cick on "save none".
