reynardlam94
Different Time Formats in the same column
I have a column containing data of different timings. I would like to know how I can convert all the timings to the same format as they are of different formats.
Race Timings
51.98 (this is in seconds:milliseconds)
52.00
52.19
01:55.8 (this is in minutes:seconds:milliseconds)
02:15.3
When I try to format all to min:s with input format as min:s, all data with seconds:milliseconds gets removed.
ron_horne
Re: Different Time Formats in the same column
Hi @reynardlam94
I wonder if this solution works for this case:
https://www.youtube.com/watch?v=NzbjVs0o6No
please do let us know if it did.
JMP has always supported many commonly used date and time formats, but there are now an infinite number of other possibilities. It's no longer necessary to manipulate data with unsupported formats into something JMP recognizes. Now you can define a custom format with Format Pattern, accessed under
ron_horne
Hi @reynardlam94
I would write a simple For Each Row(), and add in the minutes value when there isn't one
For Each Row(
  If(contains(:Race Timings, ":") == 0,
     :Race Timings = "00:" || :Race Timings
Then you will be able to convert the column using the informat method
