DashNap
Design Evaluation of a Manually Built DoE
I was wondering if it was possible to get to the design evaluation page (picture 1) of a manually built DoE in JMP (picture 2)?
Thank you!
Georg
Re: Design Evaluation of a Manually Built DoE
Yes, think so, you simply can run >> DOE >> Design Diagnostics >> Evaluate Design,
input your X and run.
Georg
Georg
Georg
DashNap
Thank you!
P_Bartell
Level VIII
The only action I'd add to @Georg 's recommendation is since the design may have originated in a non JMP application I'd spend just a few minutes examining each column's column properties dialogue to insure the data type and modeling type for each column are as desired. Last thing you want is a numeric/continuous column being treated as something else or any other undesired combination. JMP relies on these column property specifications for LOTS of behind the scenes analysis/visualization/workflow actions.
