cls8760
Descriptive statistics
I'm new to jump and I'm trying to figure out how to use descriptive statistics to compare three variables, any suggestions?
Re: Descriptive statistics
go to the pull down menus
     Tables==>Stack
Stack your 3 columns
Then go to
     Analyze==>Fit Y by X
Place the Label column from the stacking data table in the X Factor and the Data Column in the Y Response.
The resulting display will then allow you to select Means/Anova, and Mean Comparisons
     Tables==>Stack
Then go to
cls8760
Thank you so much! I was able to complete them separately but couldn't figure out how to combine them all.
