See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Dense Col Rank again
miguello
Going back to this topic:
https://community.jmp.com/t5/Discussions/How-to-tweak-Col-Rank-to-give-consecutive-numbers-when-usin...
I need something similar again, but this time I cannot sort table.
So I use formula:
Col Rank( Round( :Column ), :Category, <<tie( "minimum" ) )
It gives me  column filled with the following values: {1, 114, 340, 453, 1018, 1131, 1357}
I need to turn them into {1, 2, 3...} and so on.
One idea is to construct Associate Array where a key would be a position of the number, and the value would the same number, and then use it create a column I need. Any other suggestions?
@jthi - any suggestions?
Re: Dense Col Rank again
If you don't need a formula, Summary table can usually be used to calculate the ranks and then you can use Update to add them back to your original table.
