fsanjuan
Deleting cell values based on condition
Hi!
I'm currently working on a project using JMP/JSL and on my data, I need to delete or clear values from multiple cells based on a condition. See sample raw data and required output below.
Raw data:
Test1P/F 1Test2P/F 2Test3P/F 3Test4P/F 4Test5P/F 5
1P2P4P9F3P
5P8F4P6F2P
7P1P6F5F6F
4P1P9F9F9F
6F410F10F8F
Required Output:
1P2P4P9F**
5P8F******
7P1P6F****
4P1P9F****
6F********
What is required here is to clear all following cells once 1st F (failure) is triggered.
I'm working on large data and I believe this can only be done through scripting.
Tried looping functions but none so far works. I'm really not sure if this is even possible on JSL.
Thank you in advance for your help!
vince_faller
Re: Deleting cell values based on condition
See if this works for you.
Names default to here(1);
dt = New Table( "Example",
	Add Rows( 5 ),
	New Column( "Test1",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Selected,
		Set Values( [1, 5, 7, 4, 6] )
	New Column( "P/F 1",
		Character( 16 ),
		"Nominal",
		Set Values( {"P", "P", "P", "P", "F"} )
	New Column( "Test2",
		Numeric,
		"Continuous",
		Set Values( [2, 8, 1, 1, 4] )
	New Column( "P/F 2",
		Character( 16 ),
		"Nominal",
		Set Values( {"P", "F", "P", "P", "P"} )
	New Column( "Test3",
		Numeric,
		"Continuous",
		Set Values( [4, 4, 6, 9, 10] )
	New Column( "P/F 3",
		Character( 16 ),
		"Nominal",
		Set Values( {"P", "P", "F", "F", "F"} )
	New Column( "Test4",
		Numeric,
		"Continuous",
		Set Values( [9, 6, 5, 9, 10] )
	New Column( "P/F 4",
		Character( 16 ),
		"Nominal",
		Set Values( {"F", "F", "F", "F", "F"} )
	New Column( "Test5",
		Numeric,
		"Continuous",
		Set Values( [3, 2, 6, 9, 8] )
	New Column( "P/F 5",
		Character( 16 ),
		"Nominal",
bad_rows = [];
for(i=1, i<=ncols(dt), i++,
	col = Column(dt, i);
	if(col << Get Data Type == "Character", //this is an assumption that your P/F cols are the only char
		if(nrows(bad_rows), //check if there's anything to clear
			col[bad_rows] = ""; // clear character
		bad_rows |/= loc(col <<Get Values, "F"); // add the rows that you want to clear
			col[bad_rows] = .; // clear numeric
Vince Faller - Predictum
vince_faller
	Add Rows( 5 ),
		Numeric,
		"Continuous",
		Set Selected,
		Character( 16 ),
		"Nominal",
		Numeric,
		"Continuous",
		Character( 16 ),
		"Nominal",
		Numeric,
		"Continuous",
		Character( 16 ),
		"Nominal",
		Numeric,
		"Continuous",
		Character( 16 ),
		"Nominal",
		Numeric,
		"Continuous",
		Character( 16 ),
		"Nominal",
bad_rows = [];
fsanjuan
This really solved the problem!!! Kudos!
I was also surprised it ran less than a second for thousands of cells.
Thanks!!
