Jemster
Deleting Columns with N Null Row Values
I have a table of values with each column being an instrument and each row being a time. Some instruments have not had data recorded at enough time values in order for me to fit a meaningful model.
I am attempting to use a loop to allow me to cycle through each column in turn and check the number of values.
I have some code which find the number of values for column 80.
col_a = Column(dt_2, 80);
val_mat = col_a << Get Values;
y = sum(!is missing(val_mat));
I am attempting to adapt this code into a loop for each column in turn and delete columns with too few values.
N_loop = N Cols(dt_2);
i_loop = 2;
While (i_loop <= N_loop,
	col_loop = Column(dt_2, i_loop),
	val_loop = col_loop << Get Values,
	y_loop = sum(!is missing(val_loop)),
	If(y_loop <= 8,
		dt_2 << Delete Columns( i_loop ),
	i_temp+=1,
The error message says too many arguments.
Re: Deleting Columns with N Null Row Values
Many ways to do this. One option is to use Col Number or Col N Missing and For Each (requires JMP16)
//delete some values
dt[1::20, "name"] = "";
dt[1::30, "sex"] = "";
dt[1::40, "height"] = .;
wait(2);
row_count = N Rows(dt);
For Each({col_name}, dt << Get Column Names("String"),
//  missing_vals = Col N Missing(Column(dt, col_name));
//	found_values = row_count - missing_vals;
	found_values = Col Number(Column(dt, col_name));
	If(found_values <= 8,
		dt << Delete Column(col_name);
The reason there are too many arguments, is that, there is a second comma in the While() function.
The structure of a While() function is
While( testExpr, bodyExpr )
Note: there are only 2 arguments to the function.  The test
i_loop <= N_loop
and then the statements that are executed if the textExpr is true.  Your bodyExpr has commas after each statement, rather than semicolons.  Thus, making each statement a separate argument.
Please do not just change the commas to semicolons and run this code.  There is a logic error, which will not allow the code to ever end.  i_loop and N_loop never change in value.
There is also a faster way to check for the number of valid values in a column.  Additionally, if you are deleting columns, and your N_loop value remains fixed, N_loop is no longer the correct number of columns in the data table, once one column is deleted.  It is best to work from the last column to the first column in such cases.
Below is a rework of your script which will delete the columns where the number of valid data values is less than or equal to 8.
dt_2 = Current Data Table();
N_loop = N Cols( dt_2 );
i_loop = 2;
While( N_loop > i_loop,
	If( Col Number( As Column( dt_2, N_loop ) ) <= 8,
		dt_2 << Delete Columns( N_loop )
	N_loop -= 1;
P.S. @jthi solution is a better solution.   Your approach, with some corrections, does work.....so good job!
wait(2);
i_loop <= N_loop
i_loop = 2;
	N_loop -= 1;
