Delete specific columns
I'm trying to delete columns based on specific data in those columns. For example, if the column contains the value RA, TV, EW, or EH  I want to delete it. I've worked with the code below and no errors appear in the log, but no columns are deleted either. Thanks for any help.
dt = current data table();
for(i = 1, i<=NCol(dt), i++,
if (Column(i)== "RA" , dt<< delete columns(column(i)),
     if(Column(i) == "TV", dt << delete columns(column(i)),
  if(Column(i) == "EW", dt<< delete columns(column(i)),
    if(Column(i) == "EH", dt << delete columns(column(i))
I've also tried this
for each row(if (Column(i)== "RA" , dt<< delete columns(column(i)),
    if(Column(i) == "High Dose", dt << delete columns(column(i))
ian_jmp
Level X
Re: Delete specific columns
Here's one way:
NamesDefaultToHere(1);
// Delete columns based on contents . . .
Wait(2);
for(c = NCols(dt), c>=1, c--,
colVals = Column(c) << getValues;
if(Contains(colVals, "KATIE"), dt << deleteColumn(c));
ian_jmp
Level X
Here's one way:
Wait(2);
Works great. Thanks Ian!
