Reyhanneh
Defining constrains in a custom design
Hi Everyone, I am not sure how to define constraints for my DOE. I have the following factors:
Categorical
Denaturing agent type
Agent 1, Agent 2, Agent 3
Continuous
Denaturing agent concentration
20-100 mM
Categorical
Buffer salt type
Salt 1, Salt 2
Continuous
Buffer salt concentration
10-300
Continuous
X1
8-10
Continuous
X2
0.1-2
Continuous
X3
10-200
Continuous
X4
5-10
Continuous
X5
0.1-2
Per experiment, only one of the denaturing agents {Agent 1, Agent 2, Agent 3} and only one buffer salts {Salt 1, Salt 2} can exist.
How can I define this constraint in JMP? What should I select in the linear or disallowed combination filter?
Thanks
Re: Defining constrains in a custom design
If you define them as categorical factors, only one agent and salt will be included per run.
Reyhanneh
Hi Mark, Thanks for your reply.
