hogi
Level XIII
Decimal Separator
Is there a command to get the decimal separator defined for the current Jmp installation (on Windows)?
Via
Preferences[1] << Get();
I just get the custom locale settings, which are empty if the setting is "default".
Custom Locale Settings(
Decimal Separator(),
Thousands Separator(),
Currency Decimal Separator(),
Currency Thousands Separator()
Re: Decimal Separator
Get Locale Setting might work
Get Locale Setting("Decimal Separator");
hogi
Level XIII
Thanks, @jthi .
Great!
How did you find it?
hogi
Level XIII
Ah, Scripting Index:
TroyJones
Thank you, you saved my day.
