ENTHU
Date function in jsl.
I have a table with that has time stamp for all the rows.
But I need only last 7 days data. Is there an easy way to delete all data that is past last 7 days.
New to jsl and any inputs will be helpful.
Re: Date function in jsl.
Here is a complete script that should show you a result
Names Default to Here( 1 );
dt = New Table( "test",
	add rows( 100 ),
	New Column( "start date",
		formula( Random Uniform( Today() - In Days( 12 ), Today() ) ),
		Format( "m/d/y", 10 )
dt:start date << delete formula;
New Column( "START_SHORT_DATE",
	Formula( :start date - Time Of Day( :start date ) ),
	Format( "m/d/y", 10 ),
New Column( "Todays Date",
	Formula( Today() - Time Of Day( Today() ) ),
New Column( "Ref Date",
	Formula( Today() - In Days( 7 ) ),
Current Data Table() << select where( :Ref Date < :START_SHORT_DATE );
10 REPLIES 10
dt << select where( today() - In Days( 7 ) < :Your date column );
dt << delete rows;
This will select all rows where your date column(replace its name in the first line of the JSL), is less than the current datetime - 7 days.  Then the delete rows will delete all selected rows.
If you want the rows to be deleted to be 7 days prior to midnight, not 7 days before this point in time (today()), then you need to subtact the current time from the today() functions value.
dt << select where( today() - Time of Day( today() ) - In Days( 7 ) < :Your date column );
dt << delete rows;
ENTHU
This piece of script isnt working for me.
the " today() - Indays(7) part works but something wrong with Date comparision.
Debugger doesnt show any error but nothing happens when I run this. I am using JMP 12. Is that a problem?
I don't have JMP 12 available to me to verify if In Days() function is available.  However, since all In Days() is doing is determining the number of seconds in a day, and then multiplying the result times the number in the (7), you can just change the formula to:
today()-7*60*60*24
ENTHU
Thanks for the response.As I mentioned above, I created a new column and printed today() - In Days(7) which works perfectly fine.
After this if I try comparing 2 columns,I dont see any result/error. All date columns are numeric.
Can you show the exact code you are using that is not working, and could you supply a sample of your data table?
ENTHU
Here's the code -
Clear Symbols();
Delete Symbols();
clear globals();
//Open master data list
S = Open("C:\Enthu\sample.xlsx","invisible");
current data table(S);
New Column( "START_SHORT_DATE", Numeric, Formula( Short Date( :start date ) ), );
New Column("Todays Date", Character,Formula(Abbrev Date(today())));
New Column("Ref Date", Character,Formula(Abbrev Date(today()-In Days(7))));
S << select where( :Ref Date < :START_SHORT_DATE );
Jeff_Perkinson
The problem is that the functions Short Date() and Abbrev Date() return character strings not date values. You can't compare a date value (which is numeric) to a character string.
Try this instead:
current data table() << select where( :Ref Date < :START_SHORT_DATE );
-Jeff
ENTHU
I copied the exact same code and tried running.All columns are created properly.But the following line doesnt seem to work -
Nothing gets selected.I tried using greater than , less than and equal to operators.Nothing seems to work.
Jeff_Perkinson
Sorry I didn't catch this earlier. You'll need a Run Formulas() to ensure that all formulas are evaluated before the Select Where().
Clear Symbols();
Delete Symbols();
clear globals();
S = Open("~/Downloads/sample.xlsx");
s << run formulas();
s << select where( :Ref Date < :START_SHORT_DATE );
BTW: You don't really need all the formula columns to do this.
Clear Symbols();
Delete Symbols();
Clear Globals();
S = Open( "~/Downloads/sample.xlsx" );
s << select where(
	(Today() - Time Of Day( Today() ) - In Days( 7 )) < :start date - Time Of Day( :start date )
-Jeff
