mkennke
Date Format for a SQL (OSISOFT PI)
after some trying i was able to get data from our PI Archive. We use PI (Osisoft) to archive our process data.
With the following query I got the data but the timestamp is not there:
SELECT t1.tag, t1.time, t1.value, t1.svalue,
t1.status, t1.flags
FROM picomp t1
WHERE ( ( ( t1.tag = 'AL2_Geschwindigkeit_Linienmotor_Formerstation' ) AND ( (t1.time >= ( '2017/03/05 1:47:16 PM' )) AND (t1.time <= ( '2017/03/05 2:44:40 PM' )) ) ) )
The column for the timestamp is just empty (numeric, continous).
Then I had the idea that the column for the timestamp is not numeric. I tried to convert the time into date with the follwoing query:
SELECT t1.tag, TO_Date(SUBSTR (time, 1, 15),'yyyymmdd') time, t1.value, t1.svalue,
t1.status, t1.flags
FROM picomp t1
But there i got the error:
[PIODBC] [PIOLEDB] [SUBSTR] Overload resolution failed for (DateTime, Int16, Int16) arguments(s). [SQLSTATE=HY000]
What did I wrong?
Can anybody help me?
mkennke
Re: Date Format for a SQL (OSISOFT PI)
Ok...now it works with the following SQL
SELECT t1.tag, Cast (time as string) STRING_time, t1.value, t1.svalue,
t1.status, t1.flags
FROM picomp t1
7 REPLIES 7
A few questions here: are you trying to code the SQL manually or use Query Builder? Also what version of JMP are you using?
Thanks!
M
mkennke
I use JMP Pro 13.1.
I start with the query Builder. But I have to switch to "Custom SQL". Because the Query from the Query Builder does not work. For eample I have to delete the " ; " at the end of the query. And there are some other things. Thats annoying but manageable.
mkennke
Under the follwoing link you will find an example for this " ; " -Problem from Osisoft.
https://techsupport.osisoft.com/Troubleshooting/KB/KB01377
I think the ";" issue got fixed in 13. You might want to give it a try again. My standard advice for SQL is to let Query Builder do the coding. If you want to embed the SQL in a JSL application or something you can always pull it out after the fact - but the QB do the heavy lifting so you know it works.
Best,
M
mkennke
The ";" issue is still there. But that is not my problem. I can delete it easyly.
My Problem is that I do not get the time. It seems to be that JMP converts the time data to numeric. But in the PI Archive it seems to be a string or something relative. If I use Microsoft Access I get the time. Access tells me that the data type is "Text". Maybe I will ask OSISOFT directly how I can get the time by a SQL.
mkennke
t1.status, t1.flags
FROM picomp t1
ih
Super User (Alumni) ih
I know this is an old post, but check out the Aveva/OSISoft PI Tools Add-in, it can help write these queries for you.
