  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
Jackie_
Data connection SQL prompts
I am trying to build a query in JMP 17. The issue I'm having is the SQL server login keeps prompting often to enter the login, even when I select the column. I have used JMP 16 before and never seen this problem before. Any work around?
Thanks,
Jackie
Jackie_
Re: Data connection SQL prompts
Updated to 17.1 and it got resolved
Jackie_
