aatw
Data bars in table
is it possible to add data bars in JMP data table, in a similar fashion as in Excel? The closest I can come to is Color Gradient properties in Columns, but data bars would be preferred.
Re: Data bars in table
You could also try to play around with different display boxes and then use << get picture. For example for Big Class JMP Table using following as your formula (Expression data type)
Eval(
	Eval Expr(
		Graph Box(
			Frame Size(Col Max(:weight) * 10, 300),
			Y Scale(0, 100),
			X Scale(0, Expr(Col Max(:weight))),
			Fill Color("Red");
			Rect(0, 100, Expr(:weight), 0, 1);
			Text Color("Black");
			Text Size(200);
			Text(Center Justified, {Expr(:weight / 2), 20}, Expr(Char(:weight)));
) << get picture
You will end up with something like
Easiest would be to use Tabulate
or Table Box() with Col Plot Box()
Eval(
	Eval Expr(
		Graph Box(
			Y Scale(0, 100),
			Fill Color("Red");
			Text Size(200);
) << get picture
Level XIII
wow!
Level XIII
hard to find: suppressaxes
what is doubleBuffer?
Also, if you do not need the text inside bars, you could use Spacer Boxes instead of Graph Box. Below is quick and very hacky example (I will write better version when I have slightly more time to think about this)
dt << New Column("R", Expression, None, Formula(
	As Constant(
		left_color = "Red";
		right_color = "Green";
		minval = Col Min(:Weight);
		maxval = Col Max(:Weight);
		scaling = (maxval - minval) / 300;
		If(minval >= 0,
			minval = 0;
		If(maxval <= 0,
			maxval = 0
	If(:Weight >= 0,
		right = :Weight;
		right_filler = maxval - :Weight;
		left_filler = Abs(minval);
		left = 0;
		left = Abs(:Weight);
		left_filler = Abs(minval) - left;
		right_filler = maxval;
		right = 0;
	H List Box(align("Center"),
		Spacer Box(Size(1, 20), Color("Black")),
		Spacer Box(Size(left_filler * scaling, 20), Color("White")),
		Spacer Box(size(left * scaling, 20), color(left_color)),
		Spacer Box(size(right * scaling, 20), color(right_color)),
		Spacer Box(Size(right_filler * scaling, 20), Color("White")),
With negative values:
Also, if you would like to have feature like this in JMP, create post to JMP Wish List
Level XIII
wow, many orders of magnitude faster!
I would have edited my earlier post, but this new community layout has made user experience worse than it was before... so I will create new message (I would have liked to add spoiler tags to the JSL)
/*""" Create databar column function
Author: jthi
Creation Date: 2025-10-18
Creation JMP Version: JMP Pro 18.2.1
add_databar_column = function({dt, colname, leave_formula = 1}, {Default Local},
	newcol = Eval(Substitute(
		Expr(dt << New Column(colname || " Data Bar", Expression, None, Formula(
			As Constant(
				left_color = -15775706; // pinkish
				right_color = -11393916; // light green
				minval = Col Min(_colref_);//, Excluded());
				maxval = Col Max(_colref_);//, Excluded());
				If(minval >= 0,
					minval = 0;
				If(maxval <= 0,
					maxval = 0
				scaling = (maxval - minval) / 100;
			If(_colref_ >= 0,
				right = _colref_;
				right_filler = maxval - _colref_;
				left = 0;
				left = Abs(_colref_);
				right = 0;
			bb = Border Box(Top(2), Bottom(2), Sides(15),
					Spacer Box(Size(left_filler / scaling, 13), Color("White")),
					Spacer Box(size(left / scaling, 13), color(left_color)),
					Spacer Box(size(right / scaling, 13), color(right_color)),
					Spacer Box(Size(right_filler / scaling, 13), Color("White")),
				<< Backgroundcolor("White")
		Expr(_colref_), Name Expr(AsColumn(dt, colname));
	If(!leave_formula,
		dt << Run Formulas;
		newcol << Delete Formula;
	newcol << Set Display Width(110);
	return(newcol);
// Example
dt = open("$SAMPLE_DATA/BabySleep.jmp");
add_databar_column(dt, "Awake");
add_databar_column(dt, "Asleep");
add_databar_column(dt, "Dif");
