Jim_G_Pappas
Data Filter only by columns that are of type 'character'
col_name_list_character=dt << Get Column Names("Character");
//  would like (if possible) to only filter by columns of type character.
// Same as filtering by col_name_list_character above
Button Box( " Activate Filter ", dfilter = dt << data filter( Mode( Show( 1 ), Include( 1 ) ), add filter() ) ),
// right now, the filter box has all columns (numeric and character)
I am having a hard time figuring out how to create a data filter within my application that ONLY filters by columns of type 'character'.  A small portion of my code is attached.   Seems like this one should be easy, but I'm obviously missing something.  Any help is appreciated!
Jim Pappas
Phil_Brown
Re: Data Filter only by columns that are of type 'character'
Hi @Jim_G_Pappas
Try this:
 	dfilter = dt << data filter( Mode( Show( 1 ), Include( 1 ) ), add filter() );
 	colObjList = {};
	For( i=1, i<=NItems(col_name_list_chacter), i++,
  		InsertInto(colObjList, Column(col_name_list_chacter[i]) );
 	Eval(EvalExpr( dfilter << columns( Expr(colObjList) ) ) );
       dfilter << Display( Single Category Display );
Note the "global" application of the option as you correctly described is achieved by apply the << Display( Single Category Display ) to the Data Filter Object, rather than each column
PDB
Phil_Brown
@Jim_G_Pappas
Try adding:
  colObjList = {};
PDB
Jim_G_Pappas
That works great - I really appreciate the response!
The only issue is that all the options / levels are showing for each column.  So the filter list goes way off the bottom of the page.  I can manually solve this AFTER the filter shows up on the screen (Display Options >  Single Category Display) but am having difficulty adding this to the code.   I can do this for each column (ex.  Display( :Operator, Single Category Display ) but don't know how to "globally" do this on each column since the columns change from dataset to dataset.
Any advice on that one?
Jim Pappas
Phil_Brown
Hi @Jim_G_Pappas
Try this:
 	colObjList = {};
PDB
Jim_G_Pappas
That works great!   Thank you so much.
Jim Pappas
Phil_Brown
You're very welcome!
PDB
