Hi...
I am analysing a DOE with centerpoint runs, since we want to know if there are significant quadratic effect.
known info:
- 4 factors are involved with 4 replications in the center point
- the factorial portion of the design is a full-factorial that includes 2^4=16 runs
- so, the total number of runs of your design is 20
- each run produced 20 values (readings) a total of 20 x 20 = 400 readings
In the analysis, only 1 quadratic effect has P-value, as far as i know, as far as i have enough number of runs to estimate all the main and 2nd degree effects (2-way interactions and quadratic), JMP should be able to compute for all the needed p-values. But why am i getting this result? See attached
Please correct my understanding if im wrong, and thanks to help figure out the problem with my data
