I have a DOE that I have setup to test for curvature in a continuous factor and the centerpoint that JMP selected is different than what I want to test. For example:
Low: 20
Mid (JMP): 60; 50 is what I want to change it to
High: 100
I can manually adjust the values in the Table of the designed study but I am concerned that the Design Evaluation would then not be accurate (i.e. Power Analysis, Fraction of Design Space, VIF)
Is there a way to adjust the design earlier so that my Evaluation is accurate?
