Hi @Cedrick1,
I think @DualARIMACougar may have used an AI application software able to handle photos, like Claude, Gemini, ChatGPT, or other tools. If you upload an image in these tools and describe your needs in the prompt, you might have interesting explanations and answers. But be careful and always proof-read/validate the output given, as these tools may "hallucinate" (giving inaccurate answers due to their learning mechanisms based on correlations).
Typically in the response from @DualARIMACougar, some infos seem not correct, like the evolution of the reponse depending on "Poudre de noix de coco" (when Coco is increasing, the response decreases, not increases) and the optimal maximum thickness area (middle level of essential oil is correct, but not the amount of coco powder, which seems to be minimized, and not around 4-5).
If I have to explain your response surface plot in a fully "human"-way without AI involved :
- "Form. prév. Epaisseur (mm) 2" is the response of interest and is located on the vertical axis (z-axis).
- Two factors are displayed in the X and Y axis : "Poudre de noix de coco" (Y) and "Huile essentielle" (X). You can check the values on the axis to know what is the impact of increasing/decreasing their amount on the response (Z). X is increased from right to left, whereas Y is increased from left to right :
So when Y increases, the response decreases. For X, the pattern is curvilinear (like "-X²"), so when X increases up to around 0,74 the response increases, after this X middle value the response starts to decrease.
- A contour grid is added on the plane delimited by X and Y axis. This contour plot enables to have a 2D representation of the impact of X and Y variables on the response Z. You can more easily identify the area of interest : for example, if your goal is to minimize Z, then you need to be on the lower edges of the plane : Y high and X either high or low.
- Your surface plot is curved, showing potential quadratic effects and interaction effect for your factors. It's hard to tell which terms could be present exactly in the Formula and their relative magnitude only with this plot, but there is an option to "Show Formula" in the upper right side of the report (example on another file) :
- On a rough guess and only based on the color gradient chosen (from blue/green to red), it seems the response needs to be either on a middle target value, or minimized (as high values are in red, often a symbol of "bad"/undesirable results). In order to be in the acceptable area (green/blue ?), factor "Poudre de noix de coco" needs to be set at high levels, and "Huile essentielle" at high or low levels (to reach blue area), or middle level (to reach green area).
If you're new or need more explanation about Surface Response methodologies, I would highly recommend to attend/read/watch courses on this topic, like The Open Educator - 1. What is Response Surface Methodology, Lesson 11: Response Surface Methods and Designs | STAT 503, and practice through examples Example of a Response Surface Model.
Hope this explanation makes it clearer. If you still have questions, please share your detailed and specific questions and a dataset, so that we can reproduce the graph with the same data, it's a lot easier to explain on the same use case.
Victor GUILLER
