benson_munyan
DOE All Possible Combinations
Hello all,
I have a relatively problem that I can't seem to crack within the DOE platform. I've done it before, but now I can't recall how precisely.
I am collecting two measurements (Valence and Intensity) across 4 samples. I want to control for the order the samples are presented.  I want to create a table with all possible order of samples (preferably 2 sets, so each combination appears twice).
I have set Sample as a catagorical, 4 level factor.
I have tried time as both catagorical and continuous, without luck.
What am I missing?
Re: DOE All Possible Combinations
If I am interpreting what you are asking for, you need a Full Factorial Design with 2 Responses, and 4 Factors, each with 4 levels, and 1 Replicate.
It produces a table with a randomized order of all possible combinations times 2.
benson_munyan
Hi Jim!
Thank you for your response. That is pretty close! One thing I failed to specify was that I only need each factor to appear once in each pattern.
For Example
1234
1243
1342
1324
Peter_Bartell
Level VIII
Thinking out loud here...can you accomplish this in the Custom Design platform through using the disallowed combinations filter? Essentially you're constraining your design space so any time I see that I'm led to the JMP Custom Design platform.
If all you are looking for is a test order generator, and not a complete DOE solution, the little "brute force" script I put together will give you random test orders for all of the combinations you are looking for:
dt = New Table( "Order", New Column( "Group" ), New Column( "Order", character ), New Column( "Random" ) );
For( a = 1, a <= 4, a++,
       For( b = 1, b <= 4, b++,
              For( c = 1, c <= 4, c++,
                     For( d = 1, d <= 4, d++,
                           Pattern = Char( a ) || Char( b ) || Char( c ) || Char( d );
                           If(
                                  Sum(
                                         Contains( pattern, "1" ) > 0,
                                         Contains( pattern, "2" ) > 0,
                                         Contains( pattern, "3" ) > 0,
                                         Contains( pattern, "4" ) > 0
                                  ) == 4,
                                  dt << add rows( 2 );
                                  dt:Group[N Rows( dt ) - 1] = 1;
                                  dt:Group[N Rows( dt )] = 2;
                                  dt:Order[N Rows( dt ) - 1] = pattern;
                                   dt:Order[N Rows( dt )] = pattern;
                                  dt:Random[N Rows( dt ) - 1] = Random Uniform();
                                  dt:Random[N Rows( dt )] = Random Uniform();
dt << Sort(
       By( :Group, :Random ),
       Order( Ascending, Ascending ),
       Replace table( 1 )
dt << delete Columns("Random");
