Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Created:
Jan 31, 2022 04:20 PM
| Last Modified: Jun 8, 2023 5:45 PM(2755 views)
Good evening all,
I have this error has shown in the image attached especially for effect of species in the image which shows zero. I have looked at previous questions addressing this but it doesn't seem to clarify my issue. Why would it recognise a Nparm but fail to recognise the DF?
Created:
Jan 31, 2022 06:48 PM
| Last Modified: Jan 31, 2022 3:51 PM(2735 views)
| Posted in reply to message from Gabriel 01-31-2022
Usually this is because the model is over-specified. You have less DF's available in the data set than the model you specified and JMP usually gives a Singularity "message" as Mark suggests.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '457363' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '457363') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '457363') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
