Hi Lou,
thanks for your answer. Well actually adding manually is my workaround, but I was wondering, if the design would be somehow "better", if JMP already includes my center points up-front. Or is that anyways not the case?
Concerning the Design itself - yes, I also use Defnitive Screening Designs (and I like them), but in this particular case - I know that the factors most likely will be significant and I want to avoid iterations.
Best regards
