vkessler
Custom DOE with linear constraints
Hi DOE cracks,
we want to optimize a process with a RSM DOE.
There are 6 continuous factors; 5 responses for optimization (mostly Match Target) and a linear constraint for two of the continuous factors (kind of mixture).
The constraint is:
10 <= FactorA / FactorB <= 20
Using the custom designer platform, we tried to add mixture factors or use a script for disallowed constraints but nothing worked so far. Using the script we got the error message:
How can we add this linear constraint anyways?
Thank you very much!
Re: Custom DOE with linear constraints
If I understand your situation correctly, I think you need two constraints like this:
I think this will work.
Dan Obermiller
Dan Obermiller
vkessler
Hi Dan,
yes, with this option it did work.
We should have tried it at the beginning...
